Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert. If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry. Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
  • To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert.
  • If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry.
  • Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
  • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  • Once you've created a gap, press the flat end of an opening tool into the gap.
  • The rear glass panel is fragile and can break if you use too much force or attempt to pry with metal tools.
Pour faciliter cette étape, vous pouvez surélever le bord chauffé du téléphone en le posant sur un objet d'environ 13 mm (0,5 pouces) d'épaisseur, une gomme par exemple. Il sera plus facile d'insérer l'outil d'ouverture dans le téléphone incliné.
Si vous n'avez pas moyen de surélever le téléphone, vous pouvez faire la manipulation au bord d'une table pour obtenir le même angle (mais faites attention).
Soulevez le bord inférieur de la coque arrière avec votre ventouse pour ouvrir un léger espace entre la vitre et le châssis.
Cela nécessite un certain effort. Si vous avez du mal, refaites chauffer pour continuer à ramollir l'adhésif, puis réessayez. L'adhésif refroidit très vite, vous devrez donc peut-être vous y reprendre plusieurs fois.
Une fois que vous avez ouvert un espace, insérez-y l'extrémité plate d'un outil d'ouverture.
La vitre arrière est fragile et risque de se casser si vous forcez trop ou essayez de faire levier avec des outils en métal.
