Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
The dual rear camera has a beefy bracket that looks like it might offer some bendgate-proofing support for the delicate components. The cameras are additionally secured to the rear case with some foam adhesive to keep things from jostling out of place. These cameras really need to stay put for Portrait Mode and similar features to work their magic. Surrounding the camera housing cover glass, you can see tiny spot welds likely holding the walls of the camera bump to the case.
  • The dual rear camera has a beefy bracket that looks like it might offer some bendgate-proofing support for the delicate components.
  • The cameras are additionally secured to the rear case with some foam adhesive to keep things from jostling out of place. These cameras really need to stay put for Portrait Mode and similar features to work their magic.
  • Surrounding the camera housing cover glass, you can see tiny spot welds likely holding the walls of the camera bump to the case.
La caméra arrière double est munie d'un support assez costaud, dont la fonction pourrait consister à protéger les composants fragiles des effets du Bendgate.
Ces caméras sont doublement fixées à la coque arrière par de la mousse adhésive pour les empêcher de valser. Elles ne doivent pas bouger de leur place pour permettre au Portrait Mode et aux autres fonctions d'accomplir leur magie.
Tout autour du cache en verre de la caméra, vous pouvez apercevoir des minuscules points de soudure, probablement censés fixer les parois de la bosse de la caméra à la coque.
