Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side. Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard. To remove the battery, lift up on one side to get you fingers underneath and lift away.
  • The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side.
  • Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard.
  • To remove the battery, lift up on one side to get you fingers underneath and lift away.
Insérez ici votre traduction
