Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Continue cutting through the adhesive on the top and right sides of the phone. The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive. The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive.
  • Continue cutting through the adhesive on the top and right sides of the phone.
  • The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive.
Continuez à couper l'adhésif sur les bords supérieur et droit du téléphone.
Le capteur de proximité, le haut-parleur interne et la caméra frontale se trouvent le long du bord supérieur du téléphone, mais en dessous de l'ensemble écran. Vous ne devriez pas les toucher quand vous passez avec le médiator.
