Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert the plastic opening  tool between the rear panel and the top casing. Gently push the opening tool upwards to remove the bottom case. Follow your hand behind the tool and lift the case up gently.
  • Insert the plastic opening tool between the rear panel and the top casing. Gently push the opening tool upwards to remove the bottom case.
  • Follow your hand behind the tool and lift the case up gently.
  • If too much pressure and force is applied, you could crack one of the panels.
Insérez ici votre traduction
