Aller au contenu principal
uAttend bn6000 Screen Replacement
Ce dont vous avez besoin
  1. uAttend bn6000 Screen Replacement, Disassembly: étape 1, image 1 de 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Screen Replacement: étape 2, image 1 de 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Screen Replacement, Screen: étape 3, image 1 de 2 uAttend bn6000 Screen Replacement, Screen: étape 3, image 2 de 2
    • Remove the four 10mm PH #2 screws from the screen assembly, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the screen assembly from the housing by pulling the screen up and away from the housing.
  4. uAttend bn6000 Screen Replacement: étape 4, image 1 de 3 uAttend bn6000 Screen Replacement: étape 4, image 2 de 3 uAttend bn6000 Screen Replacement: étape 4, image 3 de 3
    • Disconnect the ZIF connector, by using the plastic opening tool to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
abdullah sumait
Membre depuis le 09/20/17
419 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 11
Total : 316
