Aller au contenu principal
uAttend bn6000 Speaker Replacement
Ce dont vous avez besoin
  1. uAttend bn6000 Speaker Replacement, Disassembly: étape 1, image 1 de 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Speaker Replacement: étape 2, image 1 de 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Speaker Replacement, Speaker: étape 3, image 1 de 1
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
  4. uAttend bn6000 Speaker Replacement: étape 4, image 1 de 2 uAttend bn6000 Speaker Replacement: étape 4, image 2 de 2
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
abdullah sumait
Membre depuis le 09/20/17
419 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 107
