Ce dont vous avez besoin
Open the latch of the accumulator on the left side.
Open the battery latch on the right side.
Remove the accumulator by simultaneously holding the right-hand latch open.
Use the Philips screwdriver to remove the two screws at the bottom of the cover.
Lift the cover at the bottom right with the iFixit Opening Tool
Lift the cover at the bottom left with the iFixit Opening Tool
Finally, remove the cover to gain access to the most important components.
Once the bottom cover is removed you can start disassembling the keyboard.
First, invert the calculator and then loosen the screw as shown in picture 2 of this step.
Then unzip the keyboard screw cover strip.
Repeat the steps in order to reassemble your device.
Merci à ces traducteurs :
100%
irlanda nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
