Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre AOC monitor, utilisez notre manuel de réparation.
There are 12 screws connecting the back of the laptop to the front, make sure to keep track  of the screws and put them back in the correct spot.
  • There are 12 screws connecting the back of the laptop to the front, make sure to keep track of the screws and put them back in the correct spot.
Ajouter un commentaire
The back of the monitor clicks right out of place with the help of a butter knife.
  • The back of the monitor clicks right out of place with the help of a butter knife.
  • When you open the monitor there is a circuit that controls the buttons on the monitor. The are two screws that connect this circuit to the back of the monitor. When you unscrew the circuit gently lift it off of the back of the monitor to remove it.
  • The First one is connected by four screws in every corner. The second bigger one is connected by 9 hooks like on a picture frame, bend them back to free the cover. For the second one you also have to unscrew the ports for the plugs, screw them to the left to take them off. Once you have lifted the tabs and unscrewed the ports, just lift it off
  • To remove this board unhook the four wires to the left and then unscrew the four screws on the board.
  • To remove the second board, unscrew the three screws and the unhook the two wires on the other circuit board to remove it.
  • The last step in to separate the layers of the screen. Simply pull the monitor of the metal and you will automatically see the layers of the screen.
riley pacello
Membre depuis le 16/04/2018
385 Réputation
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 76
Total : 276
