Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre ASUS ZenPad S8, utilisez notre manuel de réparation.
  1. ASUS ZenPad S8 Teardown, ASUS ZenPad S8 Teardown: étape 1, image 1 de 2 ASUS ZenPad S8 Teardown, ASUS ZenPad S8 Teardown: étape 1, image 2 de 2
    • ASUS ZenPad S8 outside
  2. ASUS ZenPad S8 Teardown: étape 2, image 1 de 1
    • The back case didn't use any screw or glue. The back case only use tenons to stick with front case. It's not hard to take apart.
  3. ASUS ZenPad S8 Teardown: étape 3, image 1 de 3 ASUS ZenPad S8 Teardown: étape 3, image 2 de 3 ASUS ZenPad S8 Teardown: étape 3, image 3 de 3
    • There are three big parts in tablet-- upside circuit board, battery and downside circuit board. Base on my experience, upside circuit board has more important IC chips than downside board.
  4. ASUS ZenPad S8 Teardown: étape 4, image 1 de 3 ASUS ZenPad S8 Teardown: étape 4, image 2 de 3 ASUS ZenPad S8 Teardown: étape 4, image 3 de 3
    • Let's closer look at the upside circuit board. We found 4 important IC chips.
    • Hynix 4GB LPDDR3 DRAM.
    • Intel Atom Z3580.
    • Kingston eMMC 32GB NAND Flash
    • Pixelworks PX8458WM. This is the independent high-end TV level video processor I'm looking for!!!
  5. ASUS ZenPad S8 Teardown: étape 5, image 1 de 3 ASUS ZenPad S8 Teardown: étape 5, image 2 de 3 ASUS ZenPad S8 Teardown: étape 5, image 3 de 3
    • Let's measure the size of Pixelworks IC. It's about 5mm x 5mm (0.2inch x 0.2 inch)
    • From Pixelworks CEO comment, we know ASUS ZenPad S8 use IRIS1 chip. Although IRIS1 chip also target on smartphone market, we didn't find any smartphone use IRIS1 chip yet.
    • When I ask ASUS tablet PM about the possibility of IRIS1 on smartphone, he imply the power consumption level of IRIS1 may not reach smartphone requirement. It will be more reasonable to see IRIS1 on tablet or laptop.
Ken
Membre depuis le 11/20/13
273 Réputation
1 tutoriel rédigé
15 commentaires
Step 4 , Green color highlighted part cannot be Intel atom cpu, it should be PMU
Buddhika Mahesh - Réponse
It's hated too tell from your guide, but is it possible too replace the battery?
Geoffrey Paxson - Réponse
Hi! I have a cracked screen and am looking on eBay for replacements. Most sellers only have one part, but a couple sellers have two digitizer/screen variants with the difference being the width of the connector cable. Does anyone know how to determine if there actually are two variants and if so, how to know which to order? Thanks in advance.
Zack Westlie - Réponse
I have the Asus S 8 and it too has a cracked screen. I found this video on youtube.com where a guy replaces the glass screen on an Asus Transformer. He does mention two "ribbons" inside with numbers on them and says you should look at that to order the right screen, Right now, I'm trying to find a seller with the right glass. The digitizer is okay, it is only the glass which is cracked, it still works.
https://www.youtube.com/watch?v=kmN_pDAF... is the video showing his repair.
Regards,
chita.jing@gmail.com
chita jing -
There are 2 sizes. 28mm and 26mm. If the number on the ribbon ends in 05 it's 28mm. If it ends in 06 it's 26mm. Hope this helps. It did when I fixed mine. Now if I can find a good rear housing cover for it I'll be set. Good luck.
Brett Turner -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 36
Total : 24,168
