Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Outils recommandés dans ce démontage
Introduction
I teardown a common DTV converter to see whats in it and debunk the "camera" nonsense. This little box has 16MB of RAM and an unknown speed CPU. Well, lets find out!
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Access HD Digital Converter, utilisez notre manuel de réparation.
  1. Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars? To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
    • Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars?
    • To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
    • There is also 1 clip you must undo on the back, it's visible.
    • The device takes OTA digital signals and converts it into analogue 480p. Ironic that it's called Access "HD". Composite or coaxial are your choices here.
  2. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  3. Once the cover comes off, you must disconnect the front button cable. The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
    • Once the cover comes off, you must disconnect the front button cable.
    • The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
  4. The Motherboard only takes up 2/3 of the case. The rest is empty plastic! Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
    • The Motherboard only takes up 2/3 of the case. The rest is empty plastic!
    • Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
    • 4mb Flash DRAM which contains an unknown simple menu driven OS. No advanced features whatsoever.
    • Composite video output, Power in jack
    • RF Transceivers
    • Not much to this little device. It works well at picking up free over the air television. It tends to run hot, so the CPU must not be well designed for such a simple task as decoding MPEG4 streams.
Zenitar
Membre depuis le 07/02/2010
173 Réputation
2 tutoriels rédigés
Taking the top off a product is not a teardown. :(
Ryan Guerra - Réponse
I have 2 decoders that have failed,,this is one of them. Seems to have power but doesn't decode. Need to know how to test parts and replace.
Peter Cieply - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 6,378
