Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Acer Nitro 5 AN517-52, utilisez notre manuel de réparation.
  1. Acer Nitro 5 AN517-52 Basic Teardown, Remove the back cover: étape 1, image 1 de 1
    • Remove the 12 Philips screws on the back. Slip fingernails in cracks and snap open the back all around. Be gentle and it will come off.
  2. Acer Nitro 5 AN517-52 Basic Teardown, Replace battery: étape 2, image 1 de 1
    • Remove the 2 Philips screws holding the battery. Gently twist counter-clockwise to release the corners. Unplug the connector straight, without twisting.
  3. Acer Nitro 5 AN517-52 Basic Teardown, Clean fans: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Fans are great at removing dust from the room then do not work well. Look at the right fan in the picture - dusty. Some dust can be removed with tweezers. Other dust can be blown off with a can of compressed air but put a finger on the fan to prevent it from spinning. Note that replacing the fans is not simple due to heatsink complications.
  4. Acer Nitro 5 AN517-52 Basic Teardown, SSD/HDD replacement: étape 4, image 1 de 1
    • Replacement of the SSD/HDD is suprisingly simple. Remove the 4 Philips screws, slide the drive straight to the side.
  5. Acer Nitro 5 AN517-52 Basic Teardown, Button cell replacement: étape 5, image 1 de 1
    • The small button cell is in black heatshrink, held in with one connector only. Unplug it. If you know what you are doing, solder in a new one otherwise replace the assembly.
  6. Acer Nitro 5 AN517-52 Basic Teardown, Replace speakers: étape 6, image 1 de 1
    • I you crank up the toons [sic] too much and break a speaker, they are simple to replace. Unscrew them and unplug the connectors.
    • Keyboard replacement is quite involved and susceptible to fatal damage to the laptop due to connector damage. It involves removing the battery, fans/heatsink assembly, I/O boards, shields, mother board and cutting plastic standoffs, then plastic welding them back with the new kbd. This procedure will not be covered here.
AlStu
Membre depuis le 11/20/22
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 117
30 derniers jours : 322
Total : 8,691
