Aller au contenu principal
Outils recommandés dans ce démontage
Introduction
Tearing down a water damaged Alcatel One Touch Fierce from Metro PCS.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Alcatel One Touch Fierce, utilisez notre manuel de réparation.
  1. Phillips #000 is highly recommended. As you can see i'm too broke for the iFixIt equivalent. The iSesamo is also always handy. The iSesamo is also always handy.
    • Phillips #000 is highly recommended. As you can see i'm too broke for the iFixIt equivalent.
    • The iSesamo is also always handy.
  2. This is the Metro PCS variant of the phone in a nice metallic silver color. The front of this particular device is water damaged and finger print damaged.
    • This is the Metro PCS variant of the phone in a nice metallic silver color.
    • The front of this particular device is water damaged and finger print damaged.
  3. With the back plastic removed. "DO NOT REMOVE"
    • With the back plastic removed.
    • "DO NOT REMOVE"
    • Challenge accepted
  4. The second cover is removed. We now have a better look at the components.
    • The second cover is removed. We now have a better look at the components.
  5. The battery. Doesn't last very long.
    • The battery. Doesn't last very long.
  6. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  7. The 5MP camera located on the back of the phone. The 5MP camera located on the back of the phone.
    • The 5MP camera located on the back of the phone.
  8. The daughter board contains the Micro USB port The daughter board contains the Micro USB port
    • The daughter board contains the Micro USB port
  9. The main PCB The main PCB
    • The main PCB
  10. The VGA camera located on the front of the phone. The VGA camera located on the front of the phone. The VGA camera located on the front of the phone.
    • The VGA camera located on the front of the phone.
  11. The remains of the front panel The remains of the front panel
    • The remains of the front panel
  12. Trying to remove the front panel assembly. It seemed to have quite a bit of adhesive.
    • Trying to remove the front panel assembly.
    • It seemed to have quite a bit of adhesive.
    • Luckily i have a good amount of picks available.
    • Oh no, i think i hear cracking...
  13. Crap! i totally saw this coming. To avoid this use a heat gun to loosen the glue...not too much heat though.
    • Crap! i totally saw this coming.
    • To avoid this use a heat gun to loosen the glue...not too much heat though.
  14. I now have a functional phone without an LCD screen. I now have a functional phone without an LCD screen.
    • I now have a functional phone without an LCD screen.
Jonathan Ruiz
Membre depuis le 13/12/2011
1 242 Réputation
2 tutoriels rédigés
18 commentaires
I'm so glad I found this link!!! I broke the screen on my phone two weeks after I bought it, and refused to pay someone $80 to fix it (I didn't pay that much for the phone!). I have NO experience replacing a cell phone screen and this teardown looked pretty straightforward, so I figured it was worth a try. The step by step was easy, worked perfectly, and I can finally see my screen! YAY! Thank you!
Note: Use patience, and it's a breeze!
Barbara Prather - Réponse
I also successfully repaired my phone although this guide made it seem like you couldn't do it without ruining the LCD. I'm pretty proficient in phone and electronic repair but I think even beginners could do this one. The new glass that I bought had adhesive already applied to it so I could see exactly where it would be adhered from the factory. I heated the front with a heat gun and started at the top left corner. Once I got a pick in there I started going into the gap with a little X-Acto knife, cutting away at the foam like adhesive. I worked my way down the left side, then went back to the right side, cutting as I went. When only the bottom was attached, I held the phone by the top of the glass and let it dangle. Using the heat gun on the bottom of the glass allowed the weight of the phone to separate itself from the glass. Cleaned it up and put the new glass on, works like new again.
Dan - Réponse
I'm about to give this a try Dan. Thanks for your encouragement. Just one question: how did you "clean it up" before putting on the new one? Thanks!!
Janene -
this actually helped! thanks to posted this , my screen broke and ordered it online (ebay) it took a week to get here but man i couldnt see anything with my whole screen cracked! it was cheap as well, 20 bucks with tools! but this really helped!!! just do it calm and slowly , its my first time changing a screen on a phone, this really helped! thanks!
kevin - Réponse
I cracked the camera screen on the back a week after buying the phone. Can you tell me where I can get a new one?
thanks!
Shannon - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 86
Total : 61,436
