Outils recommandés dans ce démontage
Vidéo d'introduction
Introduction
- The majority of the device is held together by standard Torx screws.
- The device construction is simple and straightforward to disassemble.
- Antenna cables are soldered to the heat sink and the connectors are hidden behind a plastic frame, The potential for ripping one of these cables is high if you are not careful during disassembly.
- All the ports are soldered to the motherboard.
Dernières pensées
Indice de réparabilité
7
Indice de réparabilité de 7 sur 10
(10 étant le plus facile à réparer)
2 commentaires
So... Where's the teardown?
David Fischer - Réponse
i believe something missing with this teardown……
Marlin Rinehart - Réponse
