The majority of the device is held together by standard Torx screws.
The device construction is simple and straightforward to disassemble.
Antenna cables are soldered to the heat sink and the connectors are hidden behind a plastic frame, The potential for ripping one of these cables is high if you are not careful during disassembly.
All the ports are soldered to the motherboard.
Indice de réparabilité
7
Indice de réparabilité de 7 sur 10
(10 étant le plus facile à réparer)
3 commentaires
So... Where's the teardown?
David Fischer - Réponse
i believe something missing with this teardown……
Marlin Rinehart - Réponse
8 microphones??!!
Christopher Delaney - Réponse
