Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Apple EarPods, utilisez notre manuel de réparation.
  1. Apple EarPods Teardown, Apple EarPods Teardown: étape 1, image 1 de 1
    • What better accessory to accompany the new-and-improved iPhone than a set of new-and-improved headphones?!? Here are some of the hot new features on Apple's freshest auditory accessory:
    • Redesigned case for improved in-ear fitment and sound distribution.
    • Exterior acoustic vents for increased bass.
    • In-line microphone and volume remote.
    • Dual-material speaker diaphragms to cut sound loss and increase output.
    • Standard issue with any new iPhone 5, iPod Touch 5th Generation, or iPod Nano 7th Generation.
  2. Apple EarPods Teardown: étape 2, image 1 de 1
    • In case you were wondering, the EarPods have a model number of MD827LL/A.
    • Apple claims that their new EarPods perform at the same level as headphones that cost hundreds of dollars more, but these sweet beat makers will only cost you $29 (plus tax, if applicable).
    • Call us skeptics if you'd like, but we're not sure how that could be accomplished with a single-driver setup.
  3. Apple EarPods Teardown: étape 3, image 1 de 2 Apple EarPods Teardown: étape 3, image 2 de 2
    • The first thing we notice (and already knew) is the totally redesigned shape of the EarPods. Apple seems to believe that cramming a perfectly round earbud into your ear is no smarter than trying to fit a square peg through a round hole.
    • With the EarPods in your ears, it's actually pretty difficult for passersby to tell that your headphones aren't just good ol' Apple Earbuds.
    • If someone can tell, they either have quite an eye for detail, or they're way too close to your face.
    • The next noticeable design feature for the EarPods is that the main speaker port faces forward, rather than directly into your ear canal.
    • Is sound that is not pointed directly at your ear drum better to listen to? We don't know, but that's the verdict of Apple's acousticians, and they get paid a lot of money to do what they do.
  4. Apple EarPods Teardown: étape 4, image 1 de 2 Apple EarPods Teardown: étape 4, image 2 de 2
    • Apple had durability in mind with the new EarPods. Notice the new remote design (left), which includes larger cable wrapping near the remote than the previous earbuds (right) to reduce strain on the wires.
    • If you're using your EarPods with an iPhone or iPod, chances are you'll be stuffing them into your pocket or backpack a lot, which can put a lot of stress on the connections.
    • To make the new EarPods more resistant to water and sweat damage Apple's designers removed the external microphone grate.
    • As an iFixit user rightfully pointed out to us, the previous microphone grate was for show only! We confirmed that no hole exists in the plastics. Thanks Todd!
    • It's finally time to crack these little guys open; this is a teardown, after all.
    • We prefer to use our guitar picks to shred a pair of EarPods instead of shredding a guitar (which would probably sound great through the EarPods).
  5. Apple EarPods Teardown: étape 6, image 1 de 3 Apple EarPods Teardown: étape 6, image 2 de 3 Apple EarPods Teardown: étape 6, image 3 de 3
    • The underside of the remote cover reveals three buttons and a microphone. No surprise here, as the remote has three buttons.
    • With a little more coaxing cutting, we are able to remove the flexible PCB within the EarPods' remote.
    • The microphone in the EarPods' remote bears the markings 2F17 045.
    • Will this microphone be similar to one of the three microphones inside the iPhone 5? Probably. Will it be the same? All will be revealed in due time three more days.
    • We also uncover another IC with the markings TI25ASGVI 079, which Chipworks believes to be a Texas Instruments ADC, or a device used for volume-control duty.
    • All these components look large when shot in our pictures, but they're quite small in real life. That's how the board looks like when compared to a U.S. dime.
  6. Apple EarPods Teardown: étape 7, image 1 de 2 Apple EarPods Teardown: étape 7, image 2 de 2
    • As a reference, here's what the insides of the old remote look like: two turntables three buttons and a microphone.
    • The control board in the old earphones isn't nearly as sealed or secured as the new EarPods, leading to a common complaint among gym-goers finding that their sweet earphones don't work so well when doused in sweat.
    • The microphone reads: S262 9164.
  7. Apple EarPods Teardown: étape 8, image 1 de 1
    • With such a tight fit between the two halves of the EarPods, simply pulling them apart wasn't an option. We knew what we needed to do.
    • We don't normally cut open earbuds, but when we do, we prefer X-Acto #11 blades.
    • This isn't something you'd want to try at home. Once these Pods are open, they're not closing back up unless you want to involve glue.
  8. Apple EarPods Teardown: étape 9, image 1 de 3 Apple EarPods Teardown: étape 9, image 2 de 3 Apple EarPods Teardown: étape 9, image 3 de 3
    • While an updated remote is nice, the real innovation in the EarPods is in the speakers.
    • Like most speakers, the speakers in the EarPods consist of a diaphragm/cone, a voice coil, a permanent magnet, and a cabinet.
    • Paper or Plastic? The voice coil is supported by a composite diaphragm made of a paper cone and a polymer surround. This is the first iteration of Apple headphones to use paper cones rather than all plastic.
    • The most exciting—and most widely publicized—feature of the EarPods is the unique teardrop-esque shape of the cabinet.
    • Yet once these guys are open, things start looking quite similar to other earbuds.
    • Apple spent a lot of time analyzing people's ears, so hopefully their external design will pay dividends in the auditory excellence department.
  9. Apple EarPods Teardown: étape 10, image 1 de 1
    • For the audiophiles, here are front and back views (top and bottom, respectively) of the separated drivers.
    • Apple's switch to paper-based speaker cones may be the source of their advertised improved low and mid-range response.
    • We also discovered that the speaker basket has a much more refined look than previous models (see comparison in next step), with a fine mesh covering the back and symmetrically-placed vents.
    • The basket is a critical component, as it must be rigid to maintain consistent sound quality while still being open enough to not inhibit movement of air behind the vibrating diaphragm.
  10. Apple EarPods Teardown: étape 11, image 1 de 1
    • Hardly peas in a pod, different revisions of Apple earbuds exhibit some drastic changes in internal construction and driver design.
    • From the top, we have:
    • Previous-generation iPhone earbuds
    • First-generation iPod earbuds
    • New-generation Apple EarPods
    • The most notable differences separating the EarPods are just what you'd expect—a drastically redesigned housing, and a new material for the speaker cone.
  11. Apple EarPods Teardown: étape 12, image 1 de 1
    • At iFixit, our bottom line is durability and repairability, and their impact on electronics waste.
    • The new Apple EarPods do have significant improvements in durability:
    • The new remote is better sealed against water damage, and features strain relief wrapping to increase the life of the cable.
    • Paper speaker cones are more resistant to tearing than plastic, decreasing the likelihood of blowing out your drivers.
    • But unfortunately, these products are still of the throw-away kind. Sourcing parts is next to impossible, and it would be a tough sell to convince someone to take apart their earbuds instead of buying a new pair. They will never be the same once taken apart.
47 commentaires
I'm not sure if my edit worked or not, but Step 4 has some incorrect information:
"To make the new EarPods more resistant to water and sweat damage, Apple's designers removed the external microphone grate."
The old microphone grate was actually just for show. There was no hole, just a recessed area and a piece of metal glued to it to indicate that it was a microphone :P
ToddKeebs - Réponse
The step was updated with a hat tip your way, Todd! The "hole" on the other side was covered by a metal piece. It was evident that no hole existed once we removed that piece, but we didn't think to do it earlier since we just *assumed* it would have a hole :)
Miroslav Djuric -
Another little correction on Step 4:
The previous design you're showing isn't in fact the previous design, just A previous design. The previous designe (starting ca. iPhone 4S) did already include a larger cable wrapping.
foobar - Réponse
I'm surprised to hear that it's "unfortunate" that these earpods are the throw-away kind. Does anyone in the world realistically repair their ear buds, especially the $30 kind? It seems like you felt obligated to put an "unfortunately" clause in your article.
Jonathan - Réponse
It's sometimes easy to forget that $30 for a pair of earbuds isn't exactly chump change. Sometimes all you can afford is just a pair of earbuds.
Growing up, if I bought a pair of $30 earbuds, I'd have to hold onto them for a long, long time. There was no "toss it in the trash because it broke" fund. If it broke, I either fixed it or didn't have earbuds. I'm willing to bet that a lot of people are in that same predicament today.
Now granted, I probably wouldn't buy these particular earbuds with my $30, but that's a different story altogether. It is, however, a shame that they — just like most other earbuds on the market — cannot be fixed if broken. I think that sentiment extends to all other non-fixable earbuds, not just the EarPods.
Miroslav Djuric -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 26
7 derniers jours : 184
30 derniers jours : 698
Total : 651,122
