Aller au contenu principal
Outils recommandés dans ce démontage
Introduction
A simple look into the Universal Dock
Need a flat nose screw driver 2.4mm
philip screw driver #1
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Apple Universal Dock Model A1256, utilisez notre manuel de réparation.
  1. Pry along the edge of the bottom of the case. It will just pop out.
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Remove the top case from the bottom.
    • Remove the top case from the bottom.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  5. The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver) The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  6. The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.) The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
Membre depuis le 23/06/2010
67 Réputation
1 tutoriel rédigé
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 22
Total : 22,342
