Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: étape 1, image 1 de 3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: étape 1, image 2 de 3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: étape 1, image 3 de 3
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
dragon788
Membre depuis le 08/20/16
696 Réputation
3 tutoriels rédigés
Équipe
ComputerPhreaks Membre de l'équipe ComputerPhreaks
Business
1 membre
3 tutoriels rédigés
2 commentaires
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - Réponse
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 24
Total : 1,174
