Aller au contenu principal
Cette vue éclatée est en cours – Recharger périodiquement pour voir les derniers changements !
Ce dont vous avez besoin
  1. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: étape 1, image 1 de 3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: étape 1, image 2 de 3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: étape 1, image 3 de 3
    • Unfold the headphones face up for easy access to the Foam Earpads.
    • Insert index finger underneath foam, pinch foam between thumb and index and slowly ease the compression fitting out of its track.
    • Repeat same process for right Earpad.
  2. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: étape 2, image 1 de 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: étape 2, image 2 de 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: étape 2, image 3 de 3
    • Remove four J1 screws.
    • Carefully lift plate to avoid putting any strain on the internal wiring. Note that connections are soldered.
    • Make sure to free the speaker wire from W shaped spring before setting the Speaker plate next to the headphone assembly.
  3. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: étape 3, image 1 de 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: étape 3, image 2 de 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: étape 3, image 3 de 3
    • Unscrew the three remaining J1 screws.
    • Lift speaker retainer away from speaker.
    • The speaker now comes away easily from the speaker plate.
  4. Audio-Technica ATH-M50x Teardown, Repeat steps 2 and 3 for Left Earpiece: étape 4, image 1 de 1
    • To remove speakers will require soldering skill.
Broske
Membre depuis le 07/20/20
181 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 35
30 derniers jours : 209
Total : 8,091
