Introduction
This CD-Radio had a broken CD player, so I decided to take it apart.
Ce dont vous avez besoin
Pop off the battery cover and remove the 6 C batteries. Keep them though, they might still be good.
Unscrew the 4 highly visible screws with the medium size screwdriver.
You'll need a longer bit or a different screwdriver for the other 3 holes. I attempted to unscrew it with my bit based driver, but was unsuccessful.
Now, hunt down all the little screws on the motherboard and remove them. There are 4 or 5, so if it doesn't want to move, it's probably being held by a screw or two.
Now that all the screws, are gone, slowly lift and remove the motherboard. I say slowly because there are still a few cables attatched to the underside.
Disconnect all cables that aren't soldered on.
Now that those cables are removed, lift the motherboard up and out... or not.
The motherboard is attached to the LCD board via one of those pesky ribbon cables that's soldered on both ends and always seems to be covered in some sticky substance.
Lift the motherboard up so you have a good view of the LCD board.
