Aller au contenu principal
Outils recommandés dans ce démontage
Introduction
The only tools needed are a philips screwdriver and a narrow putty knife.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Belkin Express Dock, utilisez notre manuel de réparation.
  1. View of the connectors
    • View of the connectors
  2. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed.
    • Use a putty knife to remove the four rubber feet. Once removed, there are 4 phillips screws to be removed.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
    • The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
  5. Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
    • Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
  6. Front and back of the board. From left to right on the front of the board the major chips are:  LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • Front and back of the board.
    • From left to right on the front of the board the major chips are: LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • From left to right on the back of the board the major chips are: Parade PS161HDM; Parade PS8301 (two); NXP ZSD310 (two); Parade PS8321. The chips seem to support HDMI/DVI conversion and Display Port!
  7. close-ups of the major chips close-ups of the major chips close-ups of the major chips
    • close-ups of the major chips
thompsonfamily
Membre depuis le 21/01/2011
217 Réputation
1 tutoriel rédigé
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 30
Total : 4,010
