Introduction
Here I show you how you can teardown your Bosch vacuum cleaner. The exact Model: BSGL5ZOO2/10
Ce dont vous avez besoin
Remove residue bag G8.
Remove HEPA high efficiency hygiene filter 579496 VZ154HFB
Remove motor protection filter 578863 VZ01MSF
Use the spudger to lever the start button upwards from the front and remove it.
Lift the top of the housing from the handle side
Remove the top of the housing towards the rear.
Remove motor cover towards the back.
Carefully remove the circuit board from the guides of the cable drum.
The motor is now accessible.
Repeat the steps in reverse order to reassemble your device.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
