Ce démontage est en cours – Recharger périodiquement pour voir les derniers changements !
Danger
Potentiellement dangereux
Risque de blessure si cette procédure n'est pas suivie correctement. Faites preuve de prudence et suivez tous les avertissements.
Danger
Outils recommandés dans ce démontage
  1. The Assembled Product, unplugged from wall
    • The Assembled Product, unplugged from wall
  2. Turn Smart Strip upside down and locate  four screw holes in corners Unscrew four corner screws with #0 Phillips Screwdriver
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. Locate four latch slots in case Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Take two halves of case apart with your hands Take two halves of case apart with your hands
    • Take two halves of case apart with your hands
  6. Lift Ground Copper Strip upward off of power plugs by hand
    • Lift Ground Copper Strip upward off of power plugs by hand
  7. Locate latch securing power plugs to bottom of case Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  8. Lift power plugs out of bottom of case along with circuit assembly Lift power plugs out of bottom of case along with circuit assembly
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
Membre depuis le 14/11/2013
194 Réputation
1 tutoriel rédigé
This is great! Thanks so much!
nils smith - Réponse
that awesome and i like how it fix
Joseph donkor - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,087
