Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Canon PowerShot N, utilisez notre manuel de réparation.
  1. Canon PowerShot N Teardown, Canon PowerShot N Teardown: étape 1, image 1 de 1
    • Locate battery housing cover.
  2. Canon PowerShot N Teardown: étape 2, image 1 de 1
    • Place finger on the textured portion of battery housing cover and slide cover in the direction indicated.
  3. Canon PowerShot N Teardown: étape 3, image 1 de 1
    • Find beige tab and push it away from the battery.
  4. Canon PowerShot N Teardown: étape 4, image 1 de 2 Canon PowerShot N Teardown: étape 4, image 2 de 2
    • Remove battery from battery slot with fingers.
  5. Canon PowerShot N Teardown: étape 5, image 1 de 1
    • Using a PH000 size screwdriver, unscrew four screws beneath screen.
  6. Canon PowerShot N Teardown: étape 6, image 1 de 1
    • Remove 2 screws on the bottom of the camera.
  7. Canon PowerShot N Teardown: étape 7, image 1 de 1
    • Remove 2 screws from the side of the camera with the on and off buttons.
  8. Canon PowerShot N Teardown: étape 8, image 1 de 1
    • Remove the back plate.
  9. Canon PowerShot N Teardown: étape 9, image 1 de 1
    • Locate 2 screws on “on/off” side of the camera and unscrew them.
  10. Canon PowerShot N Teardown: étape 10, image 1 de 1
    • Locate 2 screws on the other side of the camera and remove them.
  11. Canon PowerShot N Teardown: étape 11, image 1 de 1
    • Remove one screw from the bottom of the camera.
  12. Canon PowerShot N Teardown: étape 12, image 1 de 1
    • Remove front plate from motherboard so that one ribbon cable is exposed.
  13. Canon PowerShot N Teardown: étape 13, image 1 de 1
    • Locate the second ribbon cable.
  14. Canon PowerShot N Teardown: étape 14, image 1 de 2 Canon PowerShot N Teardown: étape 14, image 2 de 2
    • Using plastic spudger, push tab to release the ribbon cable.
  15. Canon PowerShot N Teardown: étape 15, image 1 de 1
    • Locate screw under released ribbon cable and remove it.
  16. Canon PowerShot N Teardown: étape 16, image 1 de 3 Canon PowerShot N Teardown: étape 16, image 2 de 3 Canon PowerShot N Teardown: étape 16, image 3 de 3
    • With the camera lens facing you, remove 4 screws around the lens.
  17. Canon PowerShot N Teardown: étape 17, image 1 de 1
    • Flip over and remove 1 screw from side with playback/phone options .
  18. Canon PowerShot N Teardown: étape 18, image 1 de 3 Canon PowerShot N Teardown: étape 18, image 2 de 3 Canon PowerShot N Teardown: étape 18, image 3 de 3
    • Unscrew 2 screws from top, bottom, and both sides of screen.
    • Pull off white cap which edges the screen.
  19. Canon PowerShot N Teardown: étape 20, image 1 de 2 Canon PowerShot N Teardown: étape 20, image 2 de 2
    • Remove white metal plate behind screen (tip: try not to bend).
  20. Canon PowerShot N Teardown: étape 21, image 1 de 2 Canon PowerShot N Teardown: étape 21, image 2 de 2
    • Push out LCD screen.
Jack Graver
Membre depuis le 03/04/16
313 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 6-5, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 6-5, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 23
Total : 1,434
