Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Caterpillar B15, utilisez notre manuel de réparation.
  1. Caterpillar B15 Teardown, Caterpillar B15 Teardown: étape 1, image 1 de 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Teardown: étape 2, image 1 de 2 Caterpillar B15 Teardown: étape 2, image 2 de 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Teardown: étape 3, image 1 de 2 Caterpillar B15 Teardown: étape 3, image 2 de 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 Teardown: étape 4, image 1 de 2 Caterpillar B15 Teardown: étape 4, image 2 de 2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 Teardown: étape 5, image 1 de 1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 Teardown: étape 6, image 1 de 1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 Teardown: étape 7, image 1 de 1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 Teardown: étape 8, image 1 de 1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 Teardown: étape 9, image 1 de 1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 Teardown: étape 10, image 1 de 1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 Teardown: étape 11, image 1 de 1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
Geoffrey Mosdell
Membre depuis le 10/06/14
1 119 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-7, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 membres
10 tutoriels rédigés
2 commentaires
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Laurent NOEL - Réponse
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
John Nagle - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 26
Total : 11,434
