Aller au contenu principal
Outils recommandés dans ce démontage
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Charge 3, utilisez notre manuel de réparation.
  1. Remove both T3 screws Slide off the plastic piece by lifting out and then up Slide plastic and spring assembly off the rail
    • Remove both T3 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
  2. Heat the glass screen with a blowdryer to soften the adhesives Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there Insert a razor blade between the glass and the body
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. This is how close those cables get to the edge underneath the Fitbit wording so be careful
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Lift display up gently The battery is attached with a little bit of adhesive so lift gently Remove battery connector
    • Lift display up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Remove both T2 screws Liftoff metal shield
    • Remove both T2 screws
    • Liftoff metal shield
  6. Remove two T2 screws Remove T3 screw Liftoff metal shield
    • Remove two T2 screws
    • Remove T3 screw
  7. Liftoff both display connectors Liftoff both display connectors Liftoff both display connectors
    • Liftoff both display connectors
  8. Disconnect vibrator motor Disconnect heartrate and charging connector
    • Disconnect vibrator motor
    • Disconnect heartrate and charging connector
    • Remove altimeter
  9. Remove button assembly from case Remove vibrator motor Has a slight bit of adhesive and is magnetic to the case
    • Remove button assembly from case
    • Remove vibrator motor
    • Has a slight bit of adhesive and is magnetic to the case
  10. Remove motherboard It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
    • Remove motherboard
    • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
Mathieu Mongeau
Membre depuis le 21/08/2019
351 Réputation
2 tutoriels rédigés
Équipe
Mat's Repairs Membre de l'équipe Mat's Repairs
Business
1 membre
3 tutoriels rédigés
3 commentaires
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - Réponse
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - Réponse
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 32
30 derniers jours : 173
Total : 1,928
