Introduction
Need to take apart your mug press? Button got pressed too hard and now is askew in the machine? This is the guide for you.
Place your device to be taken apart on a clean flat surface with plenty of space.
Remove two plastic screw covers from bottom using a pick tool.
remove two screws using driver.
Remove the two rubber screw covers and stick them about one inch above the screws.
Remove two screws and place aside.
Press the lever flush and remove upper plastic.
Remove six screws and place aside
Lift lever and gently remove lower plastic for lever.
Metal lever bracket needs to be in the up position.
Gently remove the housing careful to not damage the attached power and usb cables
Switch is held in place with two screws.
If the screws break lose you can replace them with HDD screws
Gently thread two HDD screws until tension holds the board in place and no further.
DO NOT OVER-TIGHTEN SCREWS.
Perform steps in reverse to reassemble being careful to place cables behind the heat shield.
