Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Dell Inspiron 1750, utilisez notre manuel de réparation.
  1. Dell Inspiron 1750 Teardown, Battery: étape 1, image 1 de 2 Dell Inspiron 1750 Teardown, Battery: étape 1, image 2 de 2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Teardown: étape 2, image 1 de 2 Dell Inspiron 1750 Teardown: étape 2, image 2 de 2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Teardown, Dell Inspiron 1750 Teardown: étape 3, image 1 de 1
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Teardown: étape 4, image 1 de 3 Dell Inspiron 1750 Teardown: étape 4, image 2 de 3 Dell Inspiron 1750 Teardown: étape 4, image 3 de 3
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Teardown: étape 5, image 1 de 3 Dell Inspiron 1750 Teardown: étape 5, image 2 de 3 Dell Inspiron 1750 Teardown: étape 5, image 3 de 3
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Teardown: étape 6, image 1 de 3 Dell Inspiron 1750 Teardown: étape 6, image 2 de 3 Dell Inspiron 1750 Teardown: étape 6, image 3 de 3
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Teardown: étape 7, image 1 de 2 Dell Inspiron 1750 Teardown: étape 7, image 2 de 2
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Teardown: étape 8, image 1 de 3 Dell Inspiron 1750 Teardown: étape 8, image 2 de 3 Dell Inspiron 1750 Teardown: étape 8, image 3 de 3
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
Pièces jointes
Jordan Nedbailo
Membre depuis le 04/07/14
687 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 6-3, Forte Spring 2014 Membre de l'équipe Cal Poly, Team 6-3, Forte Spring 2014
CPSU-FORTE-S14S6G3
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 55
Total : 20,466
