Introduction
In this guide, you will learn how to teardown and disassemble a Dell Latitude 3310 Laptop. This guide requires minimal tools and is a medium difficult for tearing down the device due to the screw sizes used in the laptop and removal of parts.
NOTICE:
- Tearing down or disassembling your device may void your warranty. To check your device warranty, contact your manufacturer or visit their website
- This is a teardown guide for the full removal of components. This guide should not be used for repair and should be used as a reference for internal components
Ce dont vous avez besoin
Make sure you have a clean desk space with plenty of room to separate components
Ensure any devices or peripherals plugged into the laptop are removed and set aside
Using the system dialog, power off the computer to prevent data loss
Loosen and remove all 10 M2.5x5 screws.
Carefully remove the bottom of the laptop by prying it from the hinges and working around the edges.
Disconnect the battery cable from the motherboard.
Remove the 4 M2x3 screws at the 4 corners of the battery.
Lift away the battery and place it on a flat surface.
Remove the top of the sheet covering the RAM
Press the metal rails aside with your fingertips.
Take the RAM out and place on a flat surface.
Remove the single M2x3 screw
Move the mounting plate aside
Disconnect the antennas
Wiggle the card away from the motherboard
Rearrange the antenna cables for easier removal of the motherboard later
Disconnect the fan from the header
Remove 2 M2x3 screws
Move the fan aside
Take the opportunity to remove dust from the fan
Remove 1 M2x3 screw and lift DP-cable mounting bracket
Move cables aside
Remove the 3 M2.5x5 screws
Lift the metal brackets.
I usually do this by opening the laptop. But be careful so it does not lift and bend the plastics under or back.
Then disconnect the DC-cable.
You can remove the DC-connector by removing this screw. No markings, but I'd say this one is M2x2.
Diconnect makred cables. Make sure to lift up locking tabs with a plastic tool. CMOS and speaker cable are disconnected by pulling on the white connector on the cable.
Remove 3 M2.5x5 screws and lift the metal hinge.
Remove 2 M2x5 screws that hold metal bracket over USB-C connector.
Remove 2 M2x5 motherboard screws
Remove 2 M2x2 I/O-board screws
Lift and move aside motherboard and I/O-board
Place on anti-stat mat or similar surface
You can simply lift away the speakers and carefully wriggle out the cables
I disconnected and removed the MB (motherboard) to KB (keyboard) cable and MB to TP(trackpad) cable.
CMOS battery is stuck to frame with glue. The last cable goes to the keyboard that is hard mounted to the frame as well.
The keyboard is hard mounted to the armrest.
You should be able to lift the armrest up like you open up the laptop and remove it from the screen.
The screen can be open by prying all around the edge and then remove 4 M2x2 or smaller screws to replace the LCD screen.
