Introduction
This guide will show you how to replace the keyboard. Because the keyboard can only be replaced from the insde this is close to a teardown.
Don't be scared, its mostly unscrewing stuff. Work methodically and lay down screws in the order you used them.
If you have questions: hit me up.
Ce dont vous avez besoin
remove 8x screws with PH1 Screwdriver
Use finger nail or operning pick between backplate and frame at the top of the device
remove battery connector by pulling up. make sure the pulling strap is turned upwards
remove 5x screws with PH1
remove speaker cable by pulling towards yourself horizontally
lift out the battery vertically.
open ribbon cable connectors by lifting up and away from you the black securing latch
carefully lift up ribbon cables and pull towards yourself
remove 6x screws using PH1
remove cable sticker from heat sink
if the thermal paste has dried out the heat sink can be stuck on. carefully wiggle it horizontally until you can lift it up vertically
start on the right side at the USB C daughter board.
lift up the motherboard where the fan used to be
you should be able disconnect the daughterboard and mother board
the USB C port on the left might be tight. Use your fingers to slightly bend the laptop casing outward to the left above the usb c port
lift out the motherboard vertically
lift out USB C daughter board vertically. use the frame bending trick if necessary
remove 1x screw with PH1
lift out daughter board vertically
carefully unstick glued on ribbon cables. use are card and pull up at 45° angle
no need to remove headphone jack cable
disconnect ribbon cable
open connector as usual
open connector from smaller ribbon cable at the white flap. NOT on top of the ribbon cable!
pull out ribbon cables
use JIS00 or J00 to remove 19x screws
go around perimeter of the backplate in a orderly fashion when removing the screws to not miss any
lift up keyboard vertically
be careful: ribbon cables might be sticky
use PH1 to unscrew backplate from front of keyboard
remove old thermal paste using isopropyl alcohol and a cloth
apply new thermal paste
when you are done with reassembly do not panic, the first boot takes a little longer after disconnecting the battery
after reassembly press inbetween keyboard keys to klick together backplate and notebook frame
3 autres ont terminé cette réparation.
