Introduction
This guide will show how to take apart this PC.
Ce dont vous avez besoin
UnPlug the two cables coming out of the hard drive
Pull the blue piece of plastic towards the bottom of the pc then lift the hard drive out
Follow the same steps in step 4 but you pull the plastic piece up and slide the drive out of the case
Pull on the white or black tabs on both sides of the ram and then remove by lifting from the sides.
Use a PH2 screwdriver to remove the screw holding the front IO in. Then push towards the screw that you just removed
Unplug the cable that says "Front USB" from the motherboard and also pull out the cable that says "Front Cable"
Pull the top flap off and then squish the two prongs in so then you can pull the sensor off. You will need to unplug the cable which is located near the "Front Panel" cable
