Ce dont vous avez besoin
The front plate is attached to the bottom with 3 clips.
Using a flathead screwdriver, pry open the first clip.
Use a flat object to hold the first clip open.
Use the flathead to open the remaining clips.
With the 2.5mm flathead, remove the rubber feet.
Unscrew the 4 screws holding the top and bottom parts of the case together.
Unscrew the screws attaching the ADSL module to the mainboard.
The mainboard:
Nanya Technology NT5DS16M16CS-5T 256Mb DDR SDRAM
Infineon Technologies PSB 6972 HL V1.2 Ethernet Switch Controller
Delta Electronics LFE8731
Delta Electronics LFE9208A
