Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre First alert smoke and carbon monoxide alarm, utilisez notre manuel de réparation.
Insert wisdom here.
  • Insert wisdom here.
Ajouter un commentaire
You're going to want to get a flat head screwdriver and pry open the clip on the inside to get to the inner part of the alarm.
  • You're going to want to get a flat head screwdriver and pry open the clip on the inside to get to the inner part of the alarm.
  • After the last step you can now see the inside.
  • Now what you should do is pop a small screwdriver into the rivet hole to unlock the battery holder.
  • Now with the the battery back area being popped out you can safely take out the ringer and the mother board of the smoke detector.
  • Electricity works in a smoke detector by detecting smoke via a air filtration tank and when it detects the smoke it send a electric signal to a air horn to beep every 3-5 seconds.
Justin Lyons
Membre depuis le 21/04/2018
133 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 42
Total : 206
