Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Floppy Disk, utilisez notre manuel de réparation.
  1. Floppy Disk Teardown, Floppy Disk Teardown: étape 1, image 1 de 2 Floppy Disk Teardown, Floppy Disk Teardown: étape 1, image 2 de 2
    • The floppy disk has gone the way of the dinosaur.
    • Except for Google's lovable jumping dinosaur.
    • These disks might hold one or two photos at best; they probably won't hold much more though at only 2MB.
    • It's worth noting that today's photos taken can be upwards of 10MB on their own!
    • We liked skimmilk05's teardown so much (and his amazing attempt at his own teardown graphic) we supplied one of our own for this truly unique community contributed teardown. - iFixit Staff <3
  2. Floppy Disk Teardown, Removing the Cover: étape 2, image 1 de 2 Floppy Disk Teardown, Removing the Cover: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Jimmy
    $7.95
    J'achète
    • Thin metal pieces are good places to start.
    • This one's so thin that you can bend it with a finger.
    • This one wasn't too hard, but if you're having trouble getting it up, a Jimmy comes in handy.
  3. Floppy Disk Teardown, Removing the Casing: étape 3, image 1 de 3 Floppy Disk Teardown, Removing the Casing: étape 3, image 2 de 3 Floppy Disk Teardown, Removing the Casing: étape 3, image 3 de 3
    • With some careful prying, the entire lid pops right off.
    • You may need a spudger, metal spudger, Jimmy, or a combination of the three to get into the crack where the metal piece once was.
    • There are little pushpins holding the two halves together, but they were pulled apart during disassembly, easy as 1, 2, 3!
    • And we get a glimpse of what's inside! Spoiler alert: not much is there.
  4. Floppy Disk Teardown, The Spring: étape 4, image 1 de 1
    • In cracking open the casing, we lost a tiny little spring.
    • Boing.
    • Boing.
    • Playtime's over. Best guess as to what it is? Keeping that metal piece over the tape inside.
  5. Floppy Disk Teardown, The Cleaning Pad: étape 5, image 1 de 1
    • On the inside, we see a small pad, probably to clean the turning disk that's inside.
    • This one was pretty nasty. Eww.
    • This pad is glued into the casing with some tough adhesive; the manufacturer really didn't want this pad coming out on its own.
    • Aha!
    • The meat n' bones of the floppy disk, the disk itself!
    • Ever wondered why the floppy disk was called the "floppy" disk, even though it was in that hard plastic case? This is why.
  6. Floppy Disk Teardown, The Disk: étape 7, image 1 de 2 Floppy Disk Teardown, The Disk: étape 7, image 2 de 2
    • More floppy goodness.
  7. Floppy Disk Teardown, Wrap-up: étape 8, image 1 de 1
    • It's a pretty simple device in all. Not much else to say here.
  8. Floppy Disk Teardown, Final Thoughts: étape 9, image 1 de 2 Floppy Disk Teardown, Final Thoughts: étape 9, image 2 de 2
    • Floppy Disk Repairability Score: 1 out of 10 (10 is the easiest to repair)
    • This antique technology has virtually no replacement parts.
    • Replacement of the tape or cleaning pads are impossible without breaking the case.
    • The cleaning pads are held on with tight adhesive, making replacement difficult.
    • Attempts to use heat to loosen adhesive may result in the case melting.
    • High susceptibility to magnets make this device very sensitive.
Seji the veggie
Membre depuis le 02/09/15
1 986 Réputation
1 tutoriel rédigé
10 commentaires
Super cool! Haven't seen a floppy disk in forever.
Taylor Whitney - Réponse
They are a tad old...haha
Seji the veggie -
This is amazeballs. Solid work!
Kay-Kay Clapp - Réponse
"floppy goodness" -- so good
Julia - Réponse
Great teardown! :)
Jeff Suovanen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 49
Total : 10,502
