Outils recommandés dans ce démontage
Introduction
The Nintendo Game Boy was originally released in 1989. While it wasn’t the first handheld game console to hit the market, it popularized the category and kickstarted the portable gaming industry.
The Nintendo Game Boy was initially released in Japan on April 21, 1989, followed by a launch in North America three months later on July 31, and in Europe over a year later. This would be the start of a handheld gaming revolution.
Tech Specs:
4.19 MHz 8-bit processor
8 KB of RAM
2.6" 160x144 LCD display
Denoted by model number DMG-01 (which stands for Dot Matrix Game), the Game Boy can be powered by either four AA batteries or an AC power adapter, the latter of which has unsurprisingly disappeared somewhere into the clutter abyss.
If you're wondering, that 800 number does still call Nintendo's support line, just in case you ever need some help with your retro handheld.
The case is held together by six tri-point Y1 screws. Even back in 1989, Nintendo thought traditional screws might be too easy for us tinkerers. Fortunately, our Mako Driver Kit comes with the necessary bit.
Nintendo was at least nice enough to include an indentation for our driver to nicely fit into within the battery compartment.
We slowly separate the two halves of the outer shell to reveal a ribbon cable booby trap! Luckily, this ribbon cable is way more difficult to damage than those you'll find in newer devices.
A firm grab and pull of the ribbon cable is all that stands between complete front and back separation.
Using an Opening Tool, we slowly start prying from the top, as the display and circuit board are ever-so-slightly glued to the case.
5 commentaires
We truly have come a long way =) Thanks for the share.
2020. Thanks
Great tear down, thank you for highlighting the chips.
Great tear down! I want to use an old gameboy to frame it like this:
https://images.squarespace-cdn.com/conte...
Regarding Step 7, it says here: “The LCD display is attached to the circuit board with clips and couple of screws. Unfortunately, the display's cable is soldered to the board.”
My question: what’s the best and cleanest way to remove the LCD display? It doesn’t have to function again afterwards, it just needs to look as nice and cleanly taken apart as possible :)
If anyone has a good hint, please let me know! Thanks!
Fanning a soldering iron back and forth on the soldered connection should do the trick!
