This guide explains the teardown of the GPS Garmin Nuvi 200.
The guide shows the parts of the device, and which of those parts are replaceable. Note that Ifixit also provides repair guides for the battery, LCD screen, speaker, and rear casing.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Garmin Nuvi 200, utilisez notre manuel de réparation .
Top left: back casing
Top right: front casing
Middle left: speaker. Part ($29) and service at portatronics.com
Middle right: motherboard
Bottom left: battery. Part ($5.20) at amazon.com
Bottom right: LCD screen. Assembly kit ($49) at portatronics.com
The Serial Number Strip is at the base of the device. Remove it to two expose two T5 Torx screws.
Using the T5 Torx screwdriver, remove the two T5 Torx screws.
Use care. Do no break apart the strip of orange tape that connects the LCD screen and motherboard (red box in third picture.)
Using the plastic opening tool, only at the bottom of the device, separate the back panel from the front panel.
Use care. The glass on top of the screen is delicate.
Using the plastic opening tool, push apart the clasps holding the LCD screen in place.
Wedge the plastic opening tool between the LCD screen and the metal frame of the device.
Using the Phillips #PH00 screwdriver remove the three screws that hold the motherboard in place.
Use Screwdriver bit #PH00 in IFixIt's Tool Kit to take out the three screws holding the motherboard in place.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Étape unique
Tutoriel complet
Petit - 600 px
Moyen - 800 px
Grand - 1200 px
Aperçu
