Introduction
How to disassemble Geek Bar disposable vaping unit.
Use a wood chisel (~1 inch) along the seam to break loose the clear cover. The cover snaps into place but may be lightly glued.
Pull out the internals. You will need to push in the on/off switch at bottom of unit to get the insides to slide out.
Detach tank. Note location of wiring if you are going to reassemble unit.
Pull off top of tank.
Pull heater unit out of steel sleeve.
Remove flat wick from heater
Observe basket style heater unit. Resistance readings: blk-grn: 1.1 ohms; blk-red: 1.1 ohms; red-grn: 2.2 ohms
Unsnap the circuit board from the L-shaped plastic holder.
View board.
The lip piece can be unsnapped from the inside, pulled out from the top and disassembled as shown.
