Introduction
Looking to get every groundbreaking teardown update? Check out our Facebook, Instagram, or Twitter. For teardowns delivered straight to your inbox, subscribe to our newsletter.
If you're looking for the pint-sized offering in this series, check out our Pixel 3a teardown.
Vidéo d'introduction
- Most components are modular and can be easily replaced once the display assembly is removed.
- Repair-friendly stretch-release adhesive secures the battery.
- The only screws are standard T3 Torx fasteners.
- The display comes off first, but is thin and poorly supported. Foam adhesive makes the opening process relatively easy.
- The myriad long, thin ribbon cables connecting the internal componentry can be obnoxious to work around, and are easy to accidentally tear.
Dernières pensées
Indice de réparabilité
6
Indice de réparabilité de 6 sur 10
(10 étant le plus facile à réparer)
0 commentaires
