Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Google Pixel Buds 2, utilisez notre manuel de réparation.
  1. Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: étape 1, image 1 de 3 Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: étape 1, image 2 de 3 Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: étape 1, image 3 de 3
    • Features:
    • Sweat and Water Resistant
    • Bluetooth® 5.0
    • Spatial vent for in-ear pressure reduction and spatial awareness
    • Dual beamforming microphones / Voice detecting accelerometer
    • Up to 5 hours of listening time and up to 2.5 hours of talk time
    • Capacitive touch sensors / Dual IR proximity sensors
  2. Google Pixel Buds 2 Teardown: étape 2, image 1 de 2 Google Pixel Buds 2 Teardown: étape 2, image 2 de 2
    • What is in the box:
    • Buds Carrying / Charging Case
    • USB 'C' Cable
    • Ear bud rubber tips for different sizes of ears
    • User's Manual
  3. Google Pixel Buds 2 Teardown: étape 3, image 1 de 3 Google Pixel Buds 2 Teardown: étape 3, image 2 de 3 Google Pixel Buds 2 Teardown: étape 3, image 3 de 3
    • Open the Google Pixel Buds Charging / Carrier case to locate the Buds
    • Once the Google Pixel Buds have been removed, and we can get a closer look at the Buds.
  4. Google Pixel Buds 2 Teardown: étape 4, image 1 de 3 Google Pixel Buds 2 Teardown: étape 4, image 2 de 3 Google Pixel Buds 2 Teardown: étape 4, image 3 de 3
    • Back View of the Buds
    • Spatial Vent
    • Connectors for Charging the Battery when in the carrier / charging case
    • IR Detector for detecting when the buds are in the charging case or in the ear
    • IR Detector for detecting when the bud is in the ear
    • Grounded Metal Grid sound chamber cover
    • Closeup view of the Grounded Metal Grid
  5. Google Pixel Buds 2 Teardown: étape 5, image 1 de 3 Google Pixel Buds 2 Teardown: étape 5, image 2 de 3 Google Pixel Buds 2 Teardown: étape 5, image 3 de 3
    • Microphone port. One on each side, and opposite one another.
    • Spatial vent / grounded mesh
    • IR Detector for in ear detection
  6. Google Pixel Buds 2 Teardown: étape 6, image 1 de 3 Google Pixel Buds 2 Teardown: étape 6, image 2 de 3 Google Pixel Buds 2 Teardown: étape 6, image 3 de 3
    • Since the Google Pixel Buds are made of plastic and are glued together, the only way in was to cut into the Google Pixel Bud. This is a destructive teardown
    • Once in, we are able to get our first look at the Google Pixel Bud's electronics. The stack up the Google Pixel Bud is as follows:
    • Touch Sensor
    • Main Circuit board
    • Battery
    • Speaker
    • Microphones
    • Charging and in Ear IR Detectors (not shown)
  7. Google Pixel Buds 2 Teardown: étape 7, image 1 de 3 Google Pixel Buds 2 Teardown: étape 7, image 2 de 3 Google Pixel Buds 2 Teardown: étape 7, image 3 de 3
    • View of the electronics when removed from the Google Pixel Bud Enclosure
    • Flex PCB based Touch Sensor
    • Main PCB. Contains MCU, Bluetooth Radio, Audio Processing, Power Management, and Sensors
    • Battery
    • MEMS Microphones
    • Speaker Coil, Speaker Magnet, and Speak Diaphragm.
    • Grounded metal grid sound channel cover
    • IR Detector for in ear detections
  8. Google Pixel Buds 2 Teardown: étape 8, image 1 de 1
    • Closeup view of the Touch Sensor Flex PCB
  9. Google Pixel Buds 2 Teardown: étape 9, image 1 de 2 Google Pixel Buds 2 Teardown: étape 9, image 2 de 2
  10. Google Pixel Buds 2 Teardown: étape 10, image 1 de 3 Google Pixel Buds 2 Teardown: étape 10, image 2 de 3 Google Pixel Buds 2 Teardown: étape 10, image 3 de 3
  11. Google Pixel Buds 2 Teardown: étape 11, image 1 de 2 Google Pixel Buds 2 Teardown: étape 11, image 2 de 2
    • Closeup view of the top side of the Main PCB
    • TI - BQ25150 - Battery Charge and Power Management
    • BES Technic - BES 2300 - Bluetooth Radio
    • Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope used for voice detection. Please leave a comment if you know this device
    • Unknown Device - T 9 51 - Could be Flash Memory or RAM. Please leave a comment if you know this device
    • Unknown Device - SR 009 - Could be Flash Memory or RAM. Please leave a comment if you know this deviceNew line.
  12. Google Pixel Buds 2 Teardown: étape 12, image 1 de 3 Google Pixel Buds 2 Teardown: étape 12, image 2 de 3 Google Pixel Buds 2 Teardown: étape 12, image 3 de 3
  13. Google Pixel Buds 2 Teardown: étape 13, image 1 de 2 Google Pixel Buds 2 Teardown: étape 13, image 2 de 2
    • Closeup view of the speaker Diaphragm
    • Speaker Coil with Speaker magnet removed
    • Speaker is ported to increase bass. Port area wraps around the outside of the speaker
  14. Google Pixel Buds 2 Teardown: étape 14, image 1 de 1
    • MEMS Microphone
    • Could not cross reference the Microphone Part Number, but it appears to be a Goertek Part. Please leave a comment if you happen to know this component
  15. Google Pixel Buds 2 Teardown: étape 15, image 1 de 1
    • Closeup view of the IR Detectors. Could not cross reference part numbers to a manufacture. Please leave a comment if you happen to know this component
    • IR Detectors are used to detect when the Bud is in the ear or in the charger
  16. Google Pixel Buds 2 Teardown: étape 16, image 1 de 1
    • Closeup view of the Battery
    • Varta, CP1240 A3, Li-Ion 3.7V, 0.2Wh
  17. Google Pixel Buds 2 Teardown: étape 17, image 1 de 1
    • Closeup view of the magnet that to holds the Bud in the charger. The magnet located is below the speaker in the sound chamber area
  18. Google Pixel Buds 2 Teardown: étape 18, image 1 de 1
    • Teardown Exploded View of the Google Pixel Buds 2
    • Before and After
Robert Shuler
Membre depuis le 03/12/19
3 549 Réputation
11 tutoriels rédigés
25 commentaires
Great teardown, I can see the effort and finesse that it took., Great job.
Steve Profit - Réponse
Great job, better than iFixit!
pcbdata - Réponse
Bru this is iFixit
Shmethan Shmichael -
Looks great…did you pop open the case as well?
trFixer - Réponse
I would also like to see teardown of the case.
Nick Knudson -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 112
30 derniers jours : 512
Total : 35,093
