Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre HP Compaq nx7010 Business Notebook, utilisez notre manuel de réparation .
A 9 year old Hewlett Packard nx7010 Business Notebook from 2004.
More specifically, its model number is Cnx7010RP745Y580Wcg25P
Back in 2004 it was a mid-range notebook priced at around A$2,000.
1.8GHz Intel Celeron single core CPU.
Windows XP Professional.
1680x1050 Anti-glare Screen (Which had a HORRIFIC ghosting effect).
A tour around the Notebook.
On the left hand side you will find a PCMCIA Card slot and the Optical drive.
On the right hand side you will find an Infra-Red window, Power jack, Kensington Lock and a fan vent.
On the back you will find VGA out, S-Video, 3x USB 2.0 ports, Phone line and Ethernet, Parallel port and FireWire (4 pin).
Here is the base of the notebook.
Product Number PQ803PA#ABG
Doors to access the battery, hard drive, RAM, CMOS battery, docking port and Mini PCI LAN network card.
Serial number is [CND4500VRZ]. Decoding it reveals the notebook was made in China in December 2004.
ALWAYS remove the main power supply when working on an electrical device (both battery and mains).
Battery part number is [337607-001]
14.8 volts.
4.4 Amps per hour (4400 mAh).
8-cell.
The battery was advertised to last for 5 hours unplugged when it was new back in 2004.
After 9 years of cell deterioration, battery life is no more than 10 minutes.
Hard Disk Drive
Fujitsu MHT2080AH PL
80.0GB capacity
5,400 revolutions per minute
IDE Interface
Made in Thailand
The notebook was available with several hard drive options. 40GB and 60GB both with 4,200rpm or 5,400rpm speeds. Also avaliable was an 80GB 5,200rpm HDD (as seen here)
S.M.A.R.T data reveals that this drive has been powered on for a total of 2 years
Mini PCI LAN Network card
Intel
Model Number [WM3B2200BG]
Wi-Fi Antennae plugs into this card
Hynix RAM from slot 1 under the base
512Mb SODIMM
333MHz
Model Number [512D16S1-6H-P]
There are two slots in the nx7010 with slot 2 being under the keyboard. The computer maxes out at only 2Gb (1Gb per slot)
CMOS battery
Maxell CR1220
3 Volts
Not very interesting
Removing the keyboard
Remove the two #0 Phillips screws from the base of the laptop
Turn the laptop over and open the lid
Undo the four clips at the top of the keyboard and flip out
Carefully undo the clip on the ribbon cable with a flat-head screw driver or spludger
Optical drive
Remove the single #0 Phillips screw
Slide out the optical drive
Model Number GWA-4080N
Manufactured with HP branding
Made in Korea in November 2004
DVD and CD compatable
RAM slot 2 located under the keyboard
It's another 512Mb DDR SODIMM made by Samsung
Product number [PC2700S-25331-A0]
4 screws remove the left speaker and fan shield
The three buttons in the speaker grille control the speakers
From top to bottom it goes Volume up, Volume down and Mute.
Remove a single screw and pry the connector for the screen from the motherboard.
After the connector is removed, the 1680x1050 15 inch (38cm) screen is free.
The display enclosure
It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together
Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
I recomend using something made from soft plastic to undo the tabs as the plastic bezel and metal back panel damage easily.
The hinges simply screw on and off
The 1680x1050 Cold Cathode Fluorescent back-lit (CCFL) display
Hitachi model number TX39D99VC1FAA
Working and/or handling CCFL displays is dangerous as they contain Mercury and run at extremely high voltages.
Separating the top from the bottom
Carefully remove both speaker, SD card, Touchpad and Bluetooth module plugs and de-route the cable that leads to the wireless module (not pictured)
After that you can lift to top from the base.
The Interior of the top panel
Contains the right hand speaker, Bluetooth module and Touchpad assembly
Mouse and status LED daughter boards
The daughter board on top controsl the on/off mouse switch. The lower daughter board has status LED's, wireless on or off switch and headphone/microphone jacks
The touchpad sensor was intergreated into the palmrest and therefore was un-removable.
First thing to be removed from the motherboard is the fan.
There are (currently) no screws securing the fan in place so removal is as simple as pulling it out.
Make sure to unplug the fan first before removing.
The wires are very delicate and are very hard to repair. Carefully pull by the plug.
The left hand speaker, metal frame and wireless communications.
The wireless (gray) cable attaches to the frame so the frame can act like an antenna.
The speaker has the model number PK230005710.
This speaker also provides 1.5 watts of sound output.
The SD card reader is located right at the front of the computer and it's screwed into the base with a single screw.
The model number is LS-1704.
Manufactured on 09/05/2003 (9th of May, 2003)
Next out is the CPU heat-sink.
It is held in with 4 sprung screws place around each corner of the CPU
The thermal paste on the CPU can be a potential health hazard. Try not to come into contact with skin.
It is recommended (but not absolutely necessary) to re-apply thermal paste once the heat-sink has been removed to avoid overheating issues.
And finally, the CPU
It's an Intel Celeron M 1.8GHz Single Core with 256k of cache.
55 million Processing Die Transistors
400MHz Front Side Bus (FSB)
Removal is as easy as turning the locking screw half a turn anti-clockwise to unlock and to then carefully lift up to remove.
CPU's are very delicate especially the pins and the thermal paste residue presents a potential health hazard.
Underneath an EMI shield (not pictured) we find the ATi Mobility Radeon 9200 graphics card.
64mb of dedicated graphical goodness
It is not integrated into the motherboard so if it fails it can replaced individually rather than having a whole motherboard or CPU replacement.
The notebook was available with the option of 32mb or 64mb dedicated graphics cards.
The removal of the motherboard.
The release button for the expansion card slot must be pressed and held in, in order to remove the motherboard.
Model Number A-1701 REV:2.0
Manufactured on the 9th of July, 2003
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Étape unique
Tutoriel complet
Petit - 600 px
Moyen - 800 px
Grand - 1200 px
Aperçu
