Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre HP Pavilion Elite, utilisez notre manuel de réparation.
  • Turn off computer.
Ajouter un commentaire
  • Unplug from wall.
  • Remove wire from power source.
  • Turn off monitors, printers, and anything else that is plugged into PC. Remove all peripherals (wires) that are plugged into the back of PC and set aside.
  • Remove screws holding PC Door in place. Slide door out, remove, and set aside
  • After door is removed you can now see and have access to most components.
  • First Remove front cover by pulling plastic clips outward with screwdriver. After all 3 clips are removed you can remove front cover.
  • Remove front mounted perhipials.
  • Unscrew front mounted perhipials.
  • Unclip front mounted perhipials.
  • Remove cage for Personal Media Drive and HDD #1. Remove rear Data Cable by pushing in sides with fingers or screwdriver.
  • Unscrew with flat head screwdriver.
  • Lay PC on its side, Locate release tab on cage, press tab with long screwdriver, and remove cage.
  • Remove cage for Personal Media Drive and HDD #1. After releasing tab you can pull cage up and out. Remove power and data cables from HDD.
  • Remove 4 Screws with flat head screwdriver.
  • Slide HDD out of cage
  • Slide new HDD into cage Replace 4 Screws with flat head screwdriver.
  • With HDD Drive removed you now have access to the 4 slots of RAM
  • Remove RAM one and a time. Push top tab, then button tab, and slide RAM out of slot
  • Set RAM in order of removal so that it can be replaced in the same order.
  • Replace RAM in same manner as removal. Gently place bottom of RAM in slot and press in until you hear it click in place.
  • Move on to replace HDD
  • Re-connect power wire and data cable to HDD
  • Slide HDD Cage back into place until locking tab clicks
  • Replace screws and tighten down
  • Re-insert data cable and push in until it clicks
  • HDD installation is finished!!
  • Move forward to completely put back together PC.
  • Connect front peripherals to case
  • Screw on 2 screws to for aux/headphone jack/usb mount
  • Run wires through plastic clip and secure
  • Push plastic housing back onto mounting area to re-attach on/off button
  • Reinstall Front and sides of case Re-insert front off case and push in until it clicks Slide door back on and screw shut
  • Plug in all wires for: monitor, mouse, keyboard, speakers, etc..
  • Connect power wire to powersource and plug into wall
  • TURN ON PC !!!!!! Your now finished and ready to use your PC with new HDD and RAM
Madison
Membre depuis le 23/04/2018
481 Réputation
1 tutoriel rédigé
Cadê fotos e tradução para Português-Br
edilson patricio - Réponse
Noot HP Pavilion Desmonte e Monte
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 37
Total : 176
