Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Outils recommandés dans ce démontage
Introduction
The Hello Zee Smart Case is a fantastic modular device, that allows for the expensive part of most battery cases to be transferred when you upgrade your phone, saving you money. In this guide, we will tear it down, to see what it looks like on the inside.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Hello Zee Smart Core, utilisez notre manuel de réparation.
  1. The silver back indicates a 64GB model The silver back indicates a 64GB model The silver back indicates a 64GB model
    • The silver back indicates a 64GB model
  2. No glue or adhesive here  just insert a metal pry tool to open
    • No glue or adhesive here just insert a metal pry tool to open
    • A corner may have a good spot for this make sure that you don’t puncture the battery
  3. Once the back is off, we see a large battery, and a circuit board There is a yellow protective covering on the board
    • Once the back is off, we see a large battery, and a circuit board
    • There is a yellow protective covering on the board
    • Replace it during reassembly
  4. Remove the screws, which can be done with the pointed tip of the pry tool, though is this is not recommended And use the pry tool to get under the board There is a microSD card in there, with 64GB on it
    • Remove the screws, which can be done with the pointed tip of the pry tool, though is this is not recommended
    • And use the pry tool to get under the board
    • There is a microSD card in there, with 64GB on it
    • Upgradeability! Horray!
  5. No adhesive here! HORRAY! Unfortunately, there’s no plug on this battery, so while removing it from the back is easy, replacements are hard We can now see the wireless charger and light array
    • No adhesive here! HORRAY!
    • Unfortunately, there’s no plug on this battery, so while removing it from the back is easy, replacements are hard
    • We can now see the wireless charger and light array
  6. Overall, is was very easy to get into, with no proprietary screws, or hard to reach parts The battery requires a soldering iron to replace, due to how it is permanently connected to the circuit board
    • Overall, is was very easy to get into, with no proprietary screws, or hard to reach parts
    • The battery requires a soldering iron to replace, due to how it is permanently connected to the circuit board
    • The storage is very very easy to upgrade to a higher capacity, which is nice
    • Nothing is attached permanently to the case, which would makes swaps of parts easy, if they weren’t all soldered to the circuit board
Levi G
Membre depuis le 13/07/2018
2 675 Réputation
20 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 263
