Aller au contenu principal
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Hitron CODA, utilisez notre manuel de réparation.
  1. Hitron CODA Teardown, Remove case screws: étape 1, image 1 de 1
    • Remove rubber covers first. Attached with some weak glue, they are relatively easy to pry away. Only the 2 at the back of the device have screws underneath.
    • Use a screwdriver to remove the screws.
  2. Hitron CODA Teardown, Pry open case tabs: étape 2, image 1 de 2 Hitron CODA Teardown, Pry open case tabs: étape 2, image 2 de 2
    • Plastic tabs line the case where the upper and lower halves meet.
    • I found it easiest to start prying from the sides of the back.
    • Keep prying until the case is fully separated and the top half lifts up/forwards.
  3. Hitron CODA Teardown, Component identification (top of PCB): étape 3, image 1 de 2 Hitron CODA Teardown, Component identification (top of PCB): étape 3, image 2 de 2
  4. Hitron CODA Teardown, Remove SoC heatsink: étape 4, image 1 de 3 Hitron CODA Teardown, Remove SoC heatsink: étape 4, image 2 de 3 Hitron CODA Teardown, Remove SoC heatsink: étape 4, image 3 de 3
    • Be careful, yanking too hard can damage/disconnect the processor.
    • Squeeze the tip of the heatsink legs (e.g. with pliers) so you can pull them back through the PCB holes.
  5. Hitron CODA Teardown, Remove RF shield: étape 5, image 1 de 2 Hitron CODA Teardown, Remove RF shield: étape 5, image 2 de 2
    • Pry up the tabs around the edge of the shield.
  6. Hitron CODA Teardown, Component identification (top, under heatsink/shield): étape 6, image 1 de 2 Hitron CODA Teardown, Component identification (top, under heatsink/shield): étape 6, image 2 de 2
  7. Hitron CODA Teardown, Remove PCB from case: étape 7, image 1 de 1
    • Lift the PCB away from the case.
  8. Hitron CODA Teardown, Component identification (bottom of PCB): étape 8, image 1 de 1
  9. Hitron CODA Teardown, Remaining components to be identified: étape 9, image 1 de 2 Hitron CODA Teardown, Remaining components to be identified: étape 9, image 2 de 2
    • Product number 383300420402-11
    • Unpopulated connector H084E0581B
    • Various test points (labeled "TPXXX")
    • 602 910
    • V39 3601 2049
    • U710
  10. Hitron CODA Teardown, Further closeups: étape 10, image 1 de 3 Hitron CODA Teardown, Further closeups: étape 10, image 2 de 3 Hitron CODA Teardown, Further closeups: étape 10, image 3 de 3
    • Insert wisdom here.
  11. Hitron CODA Teardown, Further closeups: étape 11, image 1 de 3 Hitron CODA Teardown, Further closeups: étape 11, image 2 de 3 Hitron CODA Teardown, Further closeups: étape 11, image 3 de 3
  12. Hitron CODA Teardown, Further closeups: étape 12, image 1 de 3 Hitron CODA Teardown, Further closeups: étape 12, image 2 de 3 Hitron CODA Teardown, Further closeups: étape 12, image 3 de 3
  13. Hitron CODA Teardown, Further closeups: étape 13, image 1 de 3 Hitron CODA Teardown, Further closeups: étape 13, image 2 de 3 Hitron CODA Teardown, Further closeups: étape 13, image 3 de 3
  14. Hitron CODA Teardown, Further closeups: étape 14, image 1 de 3 Hitron CODA Teardown, Further closeups: étape 14, image 2 de 3 Hitron CODA Teardown, Further closeups: étape 14, image 3 de 3
  15. Hitron CODA Teardown, Further closeups: étape 15, image 1 de 2 Hitron CODA Teardown, Further closeups: étape 15, image 2 de 2
Kyle Westhaus
Membre depuis le 05/15/20
786 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 104
Total : 531
