Introduction
This guide will show you how to teardown the handle to access the power button and motherboard.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Hoover LiNX, utilisez notre manuel de réparation.
  1. Remove the single 15mm Phillips #1 screw from the handle.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Remove the handle by pulling it up.
    • Remove the handle by pulling it up.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Remove two 15mm Phillips #1 screws from the handle.
    • Remove two 15mm Phillips #1 screws from the handle.
  5. Use a plastic opening tool to carefully pry the black cover off of the handle. Use a plastic opening tool to carefully pry the black cover off of the handle.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  6. Remove five 15mm Phillips #1 black screws from the handle. Remove five 15mm Phillips #1 black screws from the handle.
    • Remove five 15mm Phillips #1 black screws from the handle.
  7. Remove the silver plastic cover using the plastic opening tool. Remove the silver plastic cover using the plastic opening tool.
    • Remove the silver plastic cover using the plastic opening tool.
Mark Nelson
Membre depuis le 25/01/2018
392 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S7-G4, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 36
Total : 621
