Introduction
I found this device on the ground and decided to take it apart. These types of disposable devices are not made to be disassembled.
Ce dont vous avez besoin
The plastic shell is ultrasonically welded shut
I don't have images of the removal process but I used a razor to lightly go along the seam and then spit it apart with a spudger
Use the point part of the spudger to get under the port and pry it up
Use flat end of spudger to pry out chamber
Everything should now be come out of the plastic housing
