Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre IBM Travelstar DJSA-220 2.5", utilisez notre manuel de réparation.
  1. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown: étape 1, image 1 de 3 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown: étape 1, image 2 de 3 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown: étape 1, image 3 de 3
    • My Victim: a dead IBM Deathstar DJSA-220
    • 20.00GB ATA/IDE
    • 5V 500mA
    • 4200RPM
    • Original Apple OEM!
    • Let's remove the 7 T6 screws!
  2. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, The Opened Drive: étape 2, image 1 de 2 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, The Opened Drive: étape 2, image 2 de 2
    • The disc surface is mirror-like. You can even see my iPhone 3GS!
    • Parts Of The Device
    • Heads.
    • Head Motor
    • A little bag that absorbs humidity.
  3. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Taking off the Logic Board: étape 3, image 1 de 3 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Taking off the Logic Board: étape 3, image 2 de 3 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Taking off the Logic Board: étape 3, image 3 de 3
    • Turn the disc over and remove the 7 T4 screws.
    • Then comes the logic board.
    • The black tape is only foam. It doesn't stick.
    • Contacts for data transfer and head control
    • Contacts for motor power
    • If my scanner wants to work again, i'll post a high res scan of the board.
  4. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Looking at the Drive: étape 4, image 1 de 1
    • You now see the back, without the logic board.
    • Heads connector, transfers head-moves commands and data to store and read
    • Motor connector, brings power to move the discs at 4200RPM
  5. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Let's attack the inside!: étape 5, image 1 de 2 IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, Let's attack the inside!: étape 5, image 2 de 2
    • Let's attack the inside!
    • remove the two T6 screws.
    • This piece is a powerful magnet!
    • This is a PCB with a ribbon cable sticked on it
    • Remove the two T6 screws.
    • The screw is on the back, T6 too.
    • I was unable to remove that T8 screw that holds the platters. They keep turning with my screwdriver and i couldn't block it strong enough.
  6. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, The Head: étape 6, image 1 de 1
    • The head with its connector.
  7. IBM Travelstar DJSA-220 2.5'' Hard Drive Teardown, All Done: étape 7, image 1 de 1
    • Done!
    • The Screws:
    • 7 T4 screws.
    • 13 T6 screws.
    • 1 T8 screw
    • There are more screws in this hard disc than in a new MacBook!
    • Thank you for reading my first teardown :-)
joelc
Membre depuis le 01/26/10
222 Réputation
1 tutoriel rédigé
10 commentaires
is there a replacement for this drive, mine just went bad...
julie - Réponse
Hi, of course, there is! Any 2.5'' ATA hard drive should fit. Beware, some computers have a 128GB capacity limit.
joelc - Réponse
is there anything reusable from the parts aside from the magnets? can you help me figure it out where I could probably use them?
Sheena - Réponse
To be honest, not much. If the logic board is fine, you could keep it just in case a same model drive went bad on this side. The screws may be useful if you are dealing with small electronic devices. But for sure, the most interesting part is that strong magnet.
joelc -
Do you happen to know where I can find drivers to get this hard drive to work on my win 7 pc? I need to extract some data from it, thank you in advance
Ville Ahonen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 20
30 derniers jours : 62
Total : 38,757
