Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Innovative Technology iPod Docking Station IT-5022WHT, utilisez notre manuel de réparation.
Before Teardown
  • Before Teardown
  • Condition: Well used
  • Noted issue: static sound when adjusting volume.
Ajouter un commentaire
Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main.
  • Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main.
  • Remove the 9 phillips screws.
  • Speakers
  • Display & Logic Board
  • Top panel buttons board
  • Audio Jacks
  • DC Power Connector
  • Antenna
  • DC Power Board
  • Audio Jacks board
  • Remove the two screws
  • The boards are glued in, so carefully pry them out of the casing.
  • You can pull the antenna apart without opening the entire case. This is helpful if just part of the antenna is bent.
  • For full removal, remove the screw on the bottom of the box labeled "antenna", and slide the antenna out the top.
  • Coax cable connects the antenna to the tuning circuit on the upper PCB.
  • Remove three screws holding the three mounting brackets for each speaker.
  • Use a blade to remove the glue holding the speaker wires in.
  • Carefully pry the speakers off their mounting points because they are glued in.
  • Removing the LCD Panel and motherboard.
  • Remove 6 screws
  • Pry out the panel by hand
  • Careful of the volume and tuning nobs when pulling the board down
  • Check out that coil
Hi, Just wanna ask. I have this same unit but mine has a busted resistors: 1) R902 and 2) R908. Can you please help me identify the value of these 2 busted resistors? Thank you so much in advance. You can reply through my e-mail: july_477@yahoo.com
Leo - Réponse
Hi leo. I don't have the product anymore, but resistors always have a color code on them. There are infographics available online that explain the color code. That's the best I can offer.
Dylan -
  • Overall this product was pretty easy to take apart.
  • The internals were pretty easy to identify based on their location and appearance.
  • One drawback was that the speakers were glued in. The glue prevents rattling, but makes the speakers harder to get to. Some glue should be used when replacing the speakers.
  • 8/10 repairability
Dylan
Membre depuis le 24/11/2014
42 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 701
