Vidéo d'introduction
Introduction
Take a look, it's in a book—an eBook that is—the Teardown Rainbow! We're moving on over to the next tablet in Amazon's new Kindle line-up; get ready for some mad knowledge.
Hankering for more tasty tidbits? Find some bite-sized trivia on our Twitter, have a hearty meal on our Instagram, or forge a knowledge partnership via Facebook.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Kindle Fire HDX 7", utilisez notre manuel de réparation.
  1. In the game of tablets, you either win, or you put out a bunch of different versions and hope one catches on. Seriously, it's the War of the Five Kings out there. Here are the specs for the latest aspirant: 7" display with 1920 x 1200 resolution at 323 ppi
    • In the game of tablets, you either win, or you put out a bunch of different versions and hope one catches on. Seriously, it's the War of the Five Kings out there. Here are the specs for the latest aspirant:
      • 7" display with 1920 x 1200 resolution at 323 ppi
      • Quad-core 2.2 GHz Snapdragon processor
      • Dual band, dual antenna (MIMO) Wi-Fi
      • Dual stereo speakers with Dolby Audio and built-in microphone
      • Front-facing HD camera
      • 16/32/64 GB internal storage
  2. A quick inspection of the back reveals dual microphones and speaker grilles up top, with the buttons at thumb level. The buttons seem a lot more robust and conveniently located than last year's Fire HD.
    • A quick inspection of the back reveals dual microphones and speaker grilles up top, with the buttons at thumb level.
    • The buttons seem a lot more robust and conveniently located than last year's Fire HD.
    • How do you know you've got the right device? Check the model number: C9R6QM.
    • The rear case turns out to be the case, wrapping around the entire device and forming a near-unibody enclosure. We target a thin plastic bezel as the Kindle's one weakness.
    • Our little blue friend is the perfect orc tool to get us inside. But it's no easy task prying against all that adhesive.
      • Fixit doctors prescribe a dose of toasty iOpener.
    • And—ooh! Fuschia…fuchsia…pink screws.
      • It's always nice to have a reminder to think pink.
  3. While it's significantly harder than cracking open a book, we crack into our Kindle like a kid who loves lobster. With the rear case free, we rush to get inside, only to be stopped by a pesky cable tethering the two halves. No cable will keep us out. Having dispensed with the nitty, we get to the gritty: components!
    • While it's significantly harder than cracking open a book, we crack into our Kindle like a kid who loves lobster.
    • With the rear case free, we rush to get inside, only to be stopped by a pesky cable tethering the two halves.
    • No cable will keep us out. Having dispensed with the nitty, we get to the gritty: components!
      • In the Kindle Fire HD of yesteryear, the rear case was a bare piece of plastic, without any additional components.
      • This time around, all of the peripherals have been offloaded to the rear case, along with a shiny heat dissipating plate.
  4. With a bit of spudger-fu, we knock out the combination power button and micro-USB port cable. The micro-HDMI port from last year's model has been torched in favor of wireless mirroring via Miracast and the Second Screen sharing technology, coming sometime in October. We're happy to see modularity in the smaller components of the HDX. The volume buttons, microphones, and headphone jack are all separate pieces, allowing failed components to be replaced individually.
    • With a bit of spudger-fu, we knock out the combination power button and micro-USB port cable.
    • The micro-HDMI port from last year's model has been torched in favor of wireless mirroring via Miracast and the Second Screen sharing technology, coming sometime in October.
    • We're happy to see modularity in the smaller components of the HDX. The volume buttons, microphones, and headphone jack are all separate pieces, allowing failed components to be replaced individually.
  5. Say what? Speakers for the HDX are provided by Dolby. While these speakers may look small, they are reported to pump out 77 decibels. For reference, that puts these speakers somewhere between normal conversation and a lawnmower. For reference, that puts these speakers somewhere between normal conversation and a lawnmower.
  6. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  7. Antenna adventures! Where is this cable going? Nowhere. It is connected, screwed, and taped  three times  in place. It must have been an unruly child.
    • Antenna adventures! Where is this cable going?
    • Nowhere. It is connected, screwed, and taped three times in place. It must have been an unruly child.
    • This seems a little like restraining a teddy bear with a muzzle.
  8. The motherboard is out of the nest, but can it ever return home? The LCD and digitizer cables are trapped between the LCD and midframe. The only way to get the connectors reseated (aside from blind luck) is to remove the midframe from the display assembly. To make matters worse, the battery connects via spring contacts beneath the motherboard—so a battery replacement makes for an even more involved repair procedure.
    • The motherboard is out of the nest, but can it ever return home?
      • The LCD and digitizer cables are trapped between the LCD and midframe. The only way to get the connectors reseated (aside from blind luck) is to remove the midframe from the display assembly.
    • To make matters worse, the battery connects via spring contacts beneath the motherboard—so a battery replacement makes for an even more involved repair procedure.
      • What was that? The sound of the HDX's repairability score free-falling into the abyss.
  9. The back side of the motherboard is home to a few ICs:
    • The back side of the motherboard is home to a few ICs:
      • Samsung K3QF2F200B 16 Gb (2 GB) LPDDR3 SDRAM (we believe the Snapdragon 800 SoC is layered underneath)
      • Qualcomm PM8841 Power Management IC
      • Summit Microelectronics (owned by Qualcomm) SMB349 Programmable Single-Cell Lithium-Ion/Lithium-Polymer Battery Charger
  10. The front side of the motherboard contains more ICs: Maxim Integrated MAX97236 Audio Amplifier with Jack Detection
    • The front side of the motherboard contains more ICs:
      • Maxim Integrated MAX97236 Audio Amplifier with Jack Detection
      • Qualcomm PM8941 Power Management IC
      • Qualcomm WCD9320 Audio Codec
      • Qualcomm Atheros QCA6234XH Integrated Dual-Band 2x2 802.11n +Bluetooth 4.0
      • Toshiba KC4 016 PVT 20F001147
        • Upon further inspection we discovered this IC to be the Toshiba THGBMAG7A2JBAIR 128 Gb (16 GB) e-MMC NAND Flash
  11. Using all the force of our adamantium claws nylon spudgers, we manage to free the 3.8 V, 4550 mAh battery from its adhesive. For a device called the "Fire," we're having to bring a lot of our own heat: some mighty powerful adhesive holds the battery to the plastic midframe. Plastic as in not very sturdy—we were worried we might just snap the front glass or LCD right in half. It's a good thing we didn't—it's a bit too late to use the "Mayday" button.
    • Using all the force of our adamantium claws nylon spudgers, we manage to free the 3.8 V, 4550 mAh battery from its adhesive.
    • For a device called the "Fire," we're having to bring a lot of our own heat: some mighty powerful adhesive holds the battery to the plastic midframe.
      • Plastic as in not very sturdy—we were worried we might just snap the front glass or LCD right in half. It's a good thing we didn't—it's a bit too late to use the "Mayday" button.
    • We're hoping that device manufacturers won't stick to the adhesive trend. We believe that even the worst offenders have a chance for redemption.
  12. A big up-sell from the 7" Kindle Fire HD, the HDX features a front-facing camera for selfies and Skyping. If you're judging a Kindle by its cameras, here are the options for the Fall 2013 lineup:
    • A big up-sell from the 7" Kindle Fire HD, the HDX features a front-facing camera for selfies and Skyping.
    • If you're judging a Kindle by its cameras, here are the options for the Fall 2013 lineup:
      • Kindle Fire HD 7": no camera
      • Kindle Fire HDX 7": 720p front-facing camera
      • Kindle Fire HD 8.9": 720p front-facing camera
      • Kindle Fire HDX 8.9": 720p front-facing camera and 8 MP rear-facing camera
  13. Time to peel away another layer to test our midframe theory: Can we replace the motherboard with the midframe removed? A little heat from an iOpener softens the adhesive around the bezel and makes sliding an opening pick around the edge a chore, as opposed to an outright nightmare. This adhesive feels rubbery and balls up under the pick, making it pretty easy to remove the midframe. However, it will be difficult to replace; you'll need all new adhesive to get everything back together.
    • Time to peel away another layer to test our midframe theory: Can we replace the motherboard with the midframe removed?
    • A little heat from an iOpener softens the adhesive around the bezel and makes sliding an opening pick around the edge a chore, as opposed to an outright nightmare.
      • This adhesive feels rubbery and balls up under the pick, making it pretty easy to remove the midframe. However, it will be difficult to replace; you'll need all new adhesive to get everything back together.
  14. The fancy new HDX display is revealed: It's the not-so-fancily named LG LD070WU2-SM01. More ICs located on the back of the display assembly: Synaptics S7301B Touchscreen Controller.
    • The fancy new HDX display is revealed: It's the not-so-fancily named LG LD070WU2-SM01.
    • More ICs located on the back of the display assembly:
      • Synaptics S7301B Touchscreen Controller.
      • Novatek NT71392QG
      • Novatek NT50169B
  15. We suspect Amazon was feeling a little insecure when they built the HDX. Like everything else, the antenna cables are seemingly over-secured. These antenna cables are taped in multiple places, screwed down, and wrapped around the midframe—just in case. After a vicious struggle, these suckers are finally free.
    • We suspect Amazon was feeling a little insecure when they built the HDX. Like everything else, the antenna cables are seemingly over-secured.
    • These antenna cables are taped in multiple places, screwed down, and wrapped around the midframe—just in case.
    • After a vicious struggle, these suckers are finally free.
  16. Kindle Fire HDX 7" Repairability: 3 out of 10 (10 is easiest to repair) Several modular components can be replaced individually.
    • Kindle Fire HDX 7" Repairability: 3 out of 10 (10 is easiest to repair)
    • Several modular components can be replaced individually.
    • The rear case is secured with screws and clips, so it can be removed (albeit with difficulty) without heat.
    • The battery is glued in place with strong adhesive and requires motherboard removal to replace.
    • The motherboard is very difficult to replace—the midframe must be separated from the display assembly in order to reinstall it.
    • The LCD is fused to the front glass, so you'll need to replace both components in the event of a cracked screen.
21 commentaires
What a bunch of losers. Whos going to take apart their brand new tablet? "Boo Amazon for gluing it on", really? So you would rather a crappy build just so one or two nerds can take one apart? Get a life.
noone - Réponse
Guess who cares about your opinion, look at your name, for the answer.
Tim -
Cos you're a retard who doesn't know the purpose of the website you are visiting. iFixit is for the people who understand that there will come a time when you have to change the battery - typically after 1 year of daily charging.
So much for your glued crap that has to be thrown away when everybody else just opens it up to change a $30 battery.
Astar -
Where is the Quad-core 2.2 GHz Snapdragon processor?
POP - Réponse
The processor is most likely layered beneath the RAM. While we didn't desolder to make 100% certain this time, it's very common practice, and the only logical place on the board. Take a look at our first Kindle Fire teardown, where we removed the RAM to find the processor layered beneath.
Andrew Optimus Goldberg -
Voir les statistiques:
Dernières 24 heures : 18
7 derniers jours : 90
30 derniers jours : 454
Total : 86,723
