Introduction
The lamp stopped working after it fell. I found no other guide to open it so I tried my own way.
The way to open it is from the lens, but I was not able to remove it without damaging it.
The lens broke by trying to remove it because of the latch there is.
I also broke the o-ring because I first thought there was a hidden screw behind the rubber part of the lamp, but there was not.
For now, I don't have a solution to remove the lens safely. But I managed to place it back on with hot glue.
Ce dont vous avez besoin
I managed to force open it (and break the latching parts) by using flat head screwdriver and opening picks.
You can now pull from the red side, the whole assembly will come out.
The soldering tabs for the battery are very easily broken. In my case it was the part that caused the lamp to not turn on (although charging and programming was fine)
Do the steps in reverse order to mount the lamp.
If required, use hot-glue to hold the lens
2 commentaires
Like yours, my pwr too stopped working after it fell. Charging was working fine, but the light wouldn't come on. The battery in mine is shorter and wider than the one in your photo. I reinserted the battery, it didn't work. i guess it's time for the garbage. I never thought I would find guidance on disassembling this light on the internet, but I just want to say thank you for providing such valuable instructions. Your detailed steps and excellent pictures were incredibly helpful.
