Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Kodak Easyshare z650, utilisez notre manuel de réparation.
  1. Kodak Easyshare z650 Teardown, Kodak Easyshare z650 Teardown: étape 1, image 1 de 1
    • With camera turned off remove battery and memory cards.
  2. Kodak Easyshare z650 Teardown: étape 2, image 1 de 3 Kodak Easyshare z650 Teardown: étape 2, image 2 de 3 Kodak Easyshare z650 Teardown: étape 2, image 3 de 3
    • Remove: 2 screws from right side.
    • 2 screws from base.
    • 2 screws from left side.
    • With battery cover open and camera lens pointing down, gently prise the rear case free.
  3. Kodak Easyshare z650 Teardown: étape 4, image 1 de 1
    • Lift LCD clear of metal housing,
    • Then, lift tab on connector.
    • Slide out ribbon cable.
  4. Kodak Easyshare z650 Teardown: étape 5, image 1 de 1
    • Remove the 3 screws from LCD metal housing plate
    • And lift off metal housing plate.
  5. Kodak Easyshare z650 Teardown: étape 6, image 1 de 1
    • Use fingernails or small flathead screw driver to push black tabs on view finder cable connector away from board connector.
    • Slide screwdriver beneath length of flex and gently lift upwards to remove flex from connector.
    • Lift flap on lens flex and gently slide flex out.
    • Use finger nails to gently prise small white connector from LCD (bottom right of board) free.
    • Be careful, do not pull it by wires.
  6. Kodak Easyshare z650 Teardown: étape 7, image 1 de 1
    • Lift board up slightly to reveal 2 ribbon flex and 1 wire connector still attached beneath board-remove flex before lifting board off completely.
    • Remove bottom flex first.
    • Then use fingernails to gently pull out wire connector from lens.
    • And slide tabs on connectors from lens/shutter and lens screen horizontally away from board and then slide flex cables free.
  7. Kodak Easyshare z650 Teardown: étape 8, image 1 de 1
    • Slide "off" button to favorites.
    • Turn camera upside down and lift front housing over tripod screw.
    • Gently prise front housing free of main camera body.
    • Clear plastic seal and thin rubber seal on camera lens may drop out as housing is freed.
  8. Kodak Easyshare z650 Teardown: étape 9, image 1 de 2 Kodak Easyshare z650 Teardown: étape 9, image 2 de 2
    • Use fingernail or small flathead screwdriver to lift plastic tab free from uppermost board.
    • Remove button console and speaker/speaker housing from top of camera.
    • Remove 2 screws from either side of view finder.
    • Remove view finder
  9. Kodak Easyshare z650 Teardown: étape 11, image 1 de 1
    • remove 3 screws holding image screen to back of lens.
    • take care that cover and seal from screen don't fall off
  10. Kodak Easyshare z650 Teardown: étape 12, image 1 de 1
    • Turn camera over so that lens is facing you.
    • Remove 3 screws holding barrel of lens to main frame of camera.
    • Pull lens barrel towards you, take care as flexes still attached at rear of lens.
  11. Kodak Easyshare z650 Teardown: étape 13, image 1 de 1
    • Turn lens over so that rear of lens is facing up.
    • Lift flex on right of rear lens barrel to reveal screw, then remove 3 screws on rear of lens.
    • Remove 1 screw from left side of lens barrel (holding focus flex) optional step.
    • Slide flex through openings on rear lens housing to remove housing.
  12. Kodak Easyshare z650 Teardown: étape 14, image 1 de 3 Kodak Easyshare z650 Teardown: étape 14, image 2 de 3 Kodak Easyshare z650 Teardown: étape 14, image 3 de 3
    • Hold inner black lens barrel and turn anti-clockwise until inner barrel lifts out.
    • Lift inner barrel up and free from lens motor and flex assembly.
    • Holding on to pin on inside of outermost lens barrel, turn lens barrel upside down and grasp inner lens as it falls free.
pollytintop
Membre depuis le 06/09/10
77 189 Réputation
5 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 516 tutoriels rédigés
2 commentaires
jackmorin, I'm just curious; why did you feel it was necessary, to make that your comment of choice, knowing exactly what pollytintop meant; rather than, thank you for the time you put into posting this very helpful information. I would like to say, thank you pollytintop, this was very helpful & I appreciate this detailed information.
Kristen Meadows - Réponse
I would like to thank the author for putting this info together. I was able to find a video screen for the back of this cam2017era very reasonably on Ebay, and with the help of these instructions, replace the broken screen that had plagued this camera for years. It was with a gre/24/at sense of satisfaction that I can now use the camera with its full features. Thanks again!
Bill West - 4/24/2017
will.west0613 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 31
Total : 12,591
